Parametric Mullions
10 ANTWORTEN 10
Nachricht 1 von 11
ctough
1196 Aufrufe, 10 Antworten
Parametric Mullions
I've got quite a clever sash window here but I can't work out how to get the 3x2 mullions to be parametric. They're fine when resized vertically but don't work horizontally. Please see the attached.
10 ANTWORTEN 10
Nachricht 2 von 11
Alfredo_Medina
als Antwort auf: ctough
Please provide more information. You meant to post an attachment but it's missing.
Nachricht 3 von 11
ctough
als Antwort auf: Alfredo_Medina
Hi Alfredo.
The attached is a standard window from the Revit library. It had glazing bars set at 2x2. I want to change them to 2X4 but I can't work out how to get them to work parametrically. Any ideas?
Nachricht 4 von 11
Alfredo_Medina
I see that the family has a parameter called "Glazing bar thickness". Have you tried that?
Nachricht 5 von 11
Is this what you are after?
My suggestion would be to open and load into your family the OOTB "Muntin Pattern_2x3.rfa" located in the stock Revit Content Library under Windows\Nested Families\Muntin.   At minimum, open it to see how to build one of your own.
2023 attached.
Nachricht 6 von 11
@ctough wrote:
Hi Alfredo.
Regarding how to make them add or remove muntins parametrically, they need to be arrayed.  That's a little more involved. Download Marvin or Pella Windows to see how theirs are constructed.  Revit Families are available directly from their Websites.
....here's one from Marvin you can inspect:
Nachricht 7 von 11
....or you could just steal and use their muntin family in your family. I won't tell. :zwinkerndes_Gesicht:
Nachricht 8 von 11
ctough
 "Glazing bar thickness" - this seems to change the thickness, that's all.
I want the glazing bars to be evenly spaced when the window is changed in size. You'll see from the screenshot below that the default size (left) works and has 2X4 glazing bars that are evenly spaced but when I increase the size of the window, they get messed up. I don't know what I'm missing.
Nachricht 9 von 11
ctough
als Antwort auf: barthbradley
Yes, this is what I'm trying to achieve but 2X4 format.
Thanks, I've opened it. I know how to make extrusions but what I don't know how to do is make them parametric and evenly spaced.
Nachricht 10 von 11
ctough
That window is the holy grail! Exactly what I'm after, to be able to edit the amount of glazing bars/muntins. I'm not sure how to go about using array though, it's not selectable when editing the extrusion.
I've inspected the Marvin one and it's blown my mind with the formulas and parameters etc. I wouldn't know where to begin.
Nachricht 11 von 11
ctough
I wish I knew how! I've loaded it in as a family but the formulas haven't transferred over. I wish you would tell!! lol
