Parametric material tags showing material marks in elevation and question marks in plan
Hi all,
We are running into an issue where our material tags are tagging casework/furniture/countertops, etc in elevation properly but display a question mark in plan view. In plan, it will still tag and show the material marks for the floors, but not any other families. We've tried changing view templates, scales, and the objects have materials assigned to them. We are using the material tag from the autodesk library, with the change that we've edited it to display the mark rather than the material description. There are no design options in this model, and they are all in the same workset. We've also turned off any graphic overrides due to phasing. Any help would be much appreciated! Attached are some screenshots to demonstrate the issue.
