PARAMETRIC LEVEL HEIGHT
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
dm0144
955 Aufrufe, 3 Antworten
Hello everyone
I would like to change the floor height to all the floor that have same floor height (a), for ex. from 3m to 3.2m. Than I would like to change the height on the ground floor (b) and I would like all the levels above the ground floor to follow or to adjust to the ground floor but not to change their floor height (a).
Currently, I had to change all the level separately because the floor height changed. Than I had to do the same because only the ground level height changed.
Any faster way of manipulating the levels?
Regards
3 ANTWORTEN 3
Nachricht 2 von 4
L.Maas
als Antwort auf: dm0144
Not sure, If multi selection does not allow to make the correct changes (because it varies too much between the elements) then there might be some other routes.
Sometimes a schedule can help. Create a schedule with the relevant floors and then enter the values in the schedule, which can be quicker then in the model itself
Further Dynamo could be a solution. Analyze the floors and then use the script to change the parameters based on certain rules
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 4
RDAOU
@dm0144
Easy and fast way is to use a global parameter ... see the GIF below. I believe it does what you are asking for
Nachricht 4 von 4
dm0144
als Antwort auf: RDAOU
@RDAOU Thanks! Exactly what I was looking for.
