Parameters L, B and H of an object to Takeoff sheet
3 ANTWORTEN 3
Nachricht 1 von 4
327 Aufrufe, 3 Antworten
Can we take Parameters Length, Breadth and height of an object wall to take off sheet ?
3 ANTWORTEN 3
Nachricht 2 von 4
rendermaster
als Antwort auf: Anonymous
you mean this? it's accessible when adding schedule
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Nachricht 3 von 4
Smiley (zwinkernd)
Nachricht 4 von 4
Reporting Length and Breadth is easy.  Reporting Height is not so unless the wall is unmodified by Edit profile or not attached to a roof.  As you can see the example below, all three walls are reported with 10'-0" unconnected height but they are not.  If the profile of the wall is an rectangle you could create a calculated formula H = Area/L, but it would not work if the profile is of another shape (like the third wall below).
As far as the heading of the columns, you can just re-title them directly on the table or in the Format tab to anything you like, e.g. Length to L, Width to B, etc...
