How can I add color and hatching in the family parameters for this element. Thanks for the help!
It is about a table that I would like to automate with standard values and I would also like to be able to change the colors and hatching with them at once. That's what I want to achieve. But I can't find how I can do this.
@daniel.vrajitoru wrote:It is about a table that I would like to automate with standard values and I would also like to be able to change the colors and hatching with them at once. That's what I want to achieve. But I can't find how I can do this.
Table? Can you tell us what this Family is and how it is to be used in Revit?
Create different types in the family, each has a filled region type with a different color. Furthermore, you can nest that family in another family and use a family type parameter to create a drop down list.
Hi Daniel,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
