Parameter
9 ANTWORTEN 9
Nachricht 1 von 10
mattpV3END
361 Aufrufe, 9 Antworten
Parameter
I need help on a formula I need to create a cube like shape thats is adjustable with a void extrusion of 2mm I also need it to go along with the overall offset. The only part I am missing is the formula in which im able to not need to change both the offsets.
9 ANTWORTEN 9
Nachricht 2 von 10
Alfredo_Medina
als Antwort auf: mattpV3END
What do you mean "both" the offsets? Please post a sketch of what you're trying to do. A void extrusion can be in different positions on a cube.
Nachricht 3 von 10
mattpV3END
I am trying to make it as a hollow duct with a 2mm like offset basically I want the 2mm offset to go for the width and length
Nachricht 4 von 10
mattpV3END
als Antwort auf: Alfredo_Medina
Nachricht 5 von 10
2mm? You sure you want to do that? Turn Thin Lines OFF and see what linework spaced 2mm apart look like at different View Scales.
Nachricht 6 von 10
Alfredo_Medina
You know that Revit can model ducts, right?
System > duct. Or do you use Revit LT?
Nachricht 7 von 10
mattpV3END
als Antwort auf: barthbradley
ik thats what I want being able to free adjust the parameter
Nachricht 8 von 10
FWIW: If you want something square/rectangular and hollow in general, there are several Structural Framing Families that you could repurpose, such as HSS Square.rfa  located in  the Content Library under Structural Framing\Steel\AISC 15.0. Just Save the OOTB Family to another name and recategorize if need be.
Nachricht 9 von 10
A duct with 2 mm thick wall?  That is over modelling.  But if you want pain and suffering, draw the sweep outer profile then offset it in 2mm, place dimensions from inner lines to the outer lines and lock them.
Nachricht 10 von 10
@mattpV3END wrote:
  The only part I am missing is the formula.
Explain what this formula is supposed to do.  Maybe throw in a screenshot so we can follow along.
