Parameter with functionality like Assembly code and Assembly Description
esatis
Message 1 of 8
esatis
is there any native way of achieving similar functionality like Assembly Code and Description ? Meaning - I would have shared parameter and some table that holds the Description value.
The Assembly Code is great but this parameter isn't available for many elements. I want to create a Shared Parameter that would be available for almost all Revit Elements.
Replies (7)
Message 2 of 8
L.Maas
No these are special built-in cases. You might to try something with key-schedules. Unfortunately you can not create a multi-category key schedule.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
handjonathan
Hi @esatis
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Anonymous  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 4 of 8
Simon_Weel
The Assembly Codes is just a text file you can mess around with at your liking. Don't know if that's advisable? Some information about the file format: Manage Assembly Codes (autodesk.com)
Message 5 of 8
esatis
I know, but Assembly Code Parameter itself isn't available for all Revit Elements.
Message 6 of 8
esatis
not really.
Key-schedules don't provide .txt file functionality like Assembly Codes. Meaning that there is a file with a code - value type structure, so that when code is present, the value is added.
Message 7 of 8
SteveKStafford
If you're not using the Keynote tools already you could do something similar with it if you create your own custom keynote collection to reference. Otherwise...no there isn't a parameter option to "lookup" from a table.
Steve Stafford
Message 8 of 8
esatis
by "own custom keynote collection" you mean custom collection in Revit ?
