A keynote schedule writes/assigns values to parameters based on a key. You just have to add this parameter to the Key schedule fields.
You can create new project/shared parameters under Manage --> Project parameters (settings tab) --> Add and then select project/shared parameter with name under the category you want to use it for ie. parameter for walls select wall category. Then in your Keynote schedule go to fields tab and add the parameter to the schedule.
My task is too create a Parameter to rooms. I´d like the parameter to work in the same way as the Keynote does.
Is this possible?
Ow, you weren't talking about key schedules sorry I misunderstood. But in that case I can't answer your question I don't really know if that is possible...
