Parameter "Date"
4 ANTWORTEN 4
Nachricht 1 von 5
4163 Aufrufe, 4 Antworten
Parameter "Date"
Hye,
is it possible to create a shared parameter "date" ?
I don't find this possibility in Revit 2018, but does exist a plugin ?
I'd like to keep the "installation date" of different elements.
Thanks in advance.
C. Hinque
4 ANTWORTEN 4
Nachricht 2 von 5
Alfredo_Medina
als Antwort auf: Anonymous
Yes. Create a shared parameter, text, called "Date". In the project, add a Project Parameter, instance, that applies to multiple categories.
Nachricht 3 von 5
JasonKunkel
As a point of clarification, Revit does not have a Date data type to store information. That's why the parameter type suggested was Text.
Which is kind of sad, and now I have to go look at the Ideas page to see if it has been suggested.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Nachricht 4 von 5
In addition to what was suggested, use YYYY-MM-DD format when you enter the date so that you can sort them properly.
Nachricht 5 von 5
garcialuop
It seems pretty hard to understand the reason why in 2018 there is still no possibility to add a Date type parameter.
