Parameter missing in sheet
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
1183 Aufrufe, 6 Antworten
Hello! I don't understand why the red marked parameter (Project number) is missing in the title text to the left while all the other parameters (green) are there.  Can someone please help me solve this problem? I'm not very experienced with how this works.
Thanks in advance!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
It is very possible to be in another set.
Nachricht 3 von 7
What does that mean? I don’t understand :enttäuschtes_Gesicht:
Nachricht 4 von 7
Try reviewing the parameter and verify which group it is in.
Option Manage, Project Parameters
Nachricht 5 von 7
syman2000
Most likely the Project number is using the project information.
Nachricht 6 von 7
It was apparently in the identity box but unchecked for sheets in the categogories. Thanks!
Nachricht 7 von 7
If it is Project Number like you said then it should belong to Project Information, not Sheets category. And why don't you use the built-in Project Number?
