Parameter for reporting Revit version
1 ANTWORT 1
Nachricht 1 von 2
miket
594 Aufrufe, 1 Antwort
The head honcho is asking for a "note" to be put on the title sheet of our projects that will indicate which version of Revit the project was designed in.  I was hoping to come up with something that wasn't requiring user input on the part of the modeler.  Is there a way to create a parameter that will automatically report the version of Revit?
He is having issues going back and having to hunt down which version the project was designed in if he wants to open it.  We utilize BIM360 and with older projects, the fact that the models are saved over a couple of different websites in BIM360 and BIM360 Teams, it can be difficult.  Also, you can't tell just by going to the website.
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: miket
Why don't you stick that information in the Sheet via a Shared Parameter and then create a Label in the Titleblock that uses this same Shared Parameter?
...What about just putting that information in one of the in-built parameter fields under Project Information?
