i have a window tag that is a type parameter and i would like to include another parameter that shows the total count of that family type in the project. i am not sure what the category parameter i should create to add to this tag so that i will see the the window type designation letter and the count of that window type in the model.
Use a Shared Parameter and use Dynamo to count/add all Families of type X and write that value to the shared parameter
wondering how that shared parameter should be built i.e. label-category parameter (which should I choose from or build a new one)?
A shared parameter is a shared parameter, you can use it in a schedule, in a tag, in a family which you ant to schedule or tag...
Step 1:
Manage >> Shared Parameter > New Parameter (MyNewSharedParameter_Number)
Step 2:
manage >> Project parameter>>Add (and add the above to the categories where u want to use it ...example doors)
Step 3:
use dynamo to look up and create a list of all doors of one type >> count/add >> set parameter by name and records the value in the shared parameter you have created above
Step 4:
Edit your tag or create a new custom one adding the shared parameter
Step 5:
Tag Doors and you will have the total count of that type
Step 6:
Dynamo is not live, therefore whenever you add new doors you have to re-run the graph
You could also (just?) place a schedule with clear format returning the numbers, that would be live...
Do you want to repeat the count in every window tag? Do you want to reprint every sheet that has a window tag every time the window quantity is changed? What if you miss a sheet and a tag on that old sheet shows 100 windows instead of the updated 80 windows, then the contractor hold you responsible to the cost of 20 windows?
Why not simply use a window schedule to count?
A man walks into a showroom with a budget to buy a Bugatti but the sales man insisted on selling him a Kia Picanto
no wait two Kia Picantos
Or maybe he is a man who is up for the challenge and wants to take a step further beyond Revit... You ought to encourage him rather than discourage
this tag is going to be used in the "WINDOW TYPE ELEVATIONS". so right below the window elevation will be the window type mark followed by the count of said type (type mark).
I am calling Autodesk's Development team to prioritize the Idea of adding COUNT parameter to Window/Door Tags ASAP
before this post ends up a 4 pages discussion
schedule vs tag
