Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Hi there
Do you have a View Template applied to those views? If yes set it to NONE >> change parameter > then reapply View Template of the new stage.
You can attach an image in your reply if the above doesn't work
is the custom parameter a project or shared parameter?
can you recreate the parameter...shared parameter text file could have gotten corrupted somehow
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
@JasonLLINDNER I believe this is what you are experiencing And it is easy to fix...well nothing broken in it to fix! Just switch to a different template
