the panel vanished from above. reinstall did not give anything, gives a bunch of errorsTTitle renamed for clarity
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Try the following:
1. Use Autodesk Uninstall Tool to remove Revit and any addins/extensions associated with Revit
2. Download new Revit installation files (browser download)
3. Install accordingly.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hi @Anonymous
Welcome to the Autodesk Community! I see that you are visiting as a new member :smileyhappy
Sorry to hear that you are facing issues.
Did you try a repair of Revit?
Can you confirm if you have the latest updates installed from your Autodesk Desktop App for your Revit version?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
you may also want to try a Reset Revit UI.
@Anonymous Agreed with @dzanta please see How to reset the Autodesk Revit ribbon, toolbar, and browser to default settings
Let us know if you are able to resolve the issue. Looking forward to hearing from you.
Viveka
Viveka CD
If the other suggestions don't help, try taking a look at your display settings. If you happen to be using a Surface, your resolution and/or Zoom factor could be affecting your Revit session. A Zoom factor of 200% or above can be problematic and a resolution setting that is too high can be as well.
Which entries from the registry should be deleted?
Which way are they on?
@Viveka_CD wrote:Hi @Anonymous
- Repair. This option replaces all registry entries that the product initially installed and restores it to its default state. If you are missing product files, use this option.
