Panel Schedule Formulas
Does anyone know a formula to make the center column repeat the sequence A B C. I don't want to use text in these areas because of the max pole breaker parameter that is included in the schedule. That parameter will actively change the number of poles in the schedule, so I figure a formula parameter would be ideal to get the A B C sequence to show up correctly no matter the number of poles. Right now I am using a formula to get the "A" to show but need that A B C sequence to populate instead.
Any thoughts or suggestions would be very appreciated.
Thanks!
PS: This is my first time dealing with Panel Schedules in Revit so apologies if there is some very simple solution to this.
MuirEng
Our panel schedules are pretty much based on the out of the box versions and react properly to the max poles per circuit parameter. Single phase and three phase panels use the same schedule and either display AB or ABC as appropriate. Have you investigated SET TEMPLATE OPTIONS under Circuit Table? These are our settings:
Brian Muir, P.Eng, Muir Engineering
I went ahead and changed the Set Template Options and it just changed up the mirroring if the panel columns. The ABC in the center column still remains a mystery. My company is looking to have the panel schedules match our company standards which is why the schedule looks the way it does. Its been an interesting run trying to figure out how to customize the out of the box schedules. Any other ideas?
