Hello.
Anytime I try to create panel schedule is in BLANK. I've already created a new electrical project and transferred the standards (panel schedule: Branch panel) a hundred times, and still not working, the panel is still in BLANK. I even opened an old project of mine with panel schedules perfectly working, transferred the standards, and nothing. I need help!
Do you have any loads applied to the panel?
Have you ever created one before?
Help | Create a panel schedule | Autodesk
Creating Panel Schedules (youtube.com)
Did you choose a Template that you Transferred into Project?
...if not, right-click on the Panel Schedule you created in the Project Browser and select "Change Template". Then select the Template to apply.
Let's see your file. Post it here. In fact, post both files: the one you're working on and the one you're transferring schedules from.
Here you go. I hope you find something
Transfer Project Standards from the Multi Discipline template and use the panel schedule template below:
No issues here with either Project.
REPORTING SOLE PANELBOARD IN A-2024-06-2531 EAGLE-JUNE-06.rvt:
