pairing vector data and text data in revit
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
20202109010
371 Aufrufe, 1 Antwort
I hope all of you are doing well.
I have shp data that involves some id numbers on buildings' vector data. I want to get the id numbers as well as vector data on Revit together in pairs.
  1. I exported id numbers data as excel file and I am trying to import it in Revit using Dynamo, I could import titles(meta data) in Revit but couldn't get id's into Revit I will create a schedule in Revit.
  2. I also exported vector data as dxf file and imported into Revit but the dxf file came vertically.
My problem is after importing them into Revit successfully how can I pair them? Do you have any idea? is there any tool that get all data ( text information and vector information) from Qgis to revit together.
Vector data is seen like this in Qgis. all buildings have IDs in them.
1 ANTWORT 1
Nachricht 2 von 2
20202109010
als Antwort auf: 20202109010
Thankfully I get help from other architects.
There are 2 solutions
1- Via speckle, I could get the attributes of shp together on Dynamo.
2 - The other method for getting them on Dynamo is exporting them as Geojson (new line delimited) from Qgis.
