Hello all,
Will it be possible one day to select multiple faces and apply paint in 1 go ? (talking about IFC files where each object has a ducplicate materials for example). Is there maybe a Dynamo for this ?
Also, when will an material eyedropper tool be available. It would be so convenient.
Thank you,
I don't know about a paint tool for multiple faces, but there is a Dynamo script and a plugin for creating multiple walls from rooms. You can create a wall named 'paint' and apply it.
PLUGIN: https://apps.autodesk.com/RVT/en/Detail/Index?id=5641957956279354474&appLang=en&os=Win64
DYN SCRIPT: https://www.modelical.com/en/node/wall-finishes-by-room/comment-page-4/
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Use PyRevit Match Paint tool. It is literally Eyedropper with a better name.
