Painted material not centered
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
htews
361 Aufrufe, 2 Antworten
I created an exterior material in PShop with the correct sizing. I created a new material and added the jpg, centered horizontally and vertically. when I applied the material, its not centered as I thought it would have done. 1 wall its centered while another is not.
according to the texture editor, it should be centered.centered material.pngtered.
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: htews
Try this -
https://knowledge.autodesk.com/support/revit-products/downloads/caas/CloudHelp/cloudhelp/2016/ENU/Re...
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
htews
als Antwort auf: Sahay_R
the elevations are set to 'Realistic'.  I know you can move the texture around in hidden line and shaded.
...*time lapse*...
oh! so they ARE connected.
EXCELLENT!
Thank you!
 Kudos!
