Paint align
6 ANTWORTEN 6
Nachricht 1 von 7
jfjacques
1455 Aufrufe, 6 Antworten
Paint align
For some reason this paint material cannot be aligned/moved to match the others.
6 ANTWORTEN 6
Nachricht 2 von 7
Martijn.Pater
als Antwort auf: jfjacques
Is this a surface model pattern defined in the material? If not, that's probably your answer...
Nachricht 3 von 7
jfjacques
als Antwort auf: Martijn.Pater
Seems to be a bug.
I tried removing the pt material and then replacing the roof materials with the pattern but nothing shows up.
This is likely because the mat is being applied to the side of an extruded roof and there's not face.
I guess I have to build a facia or something?
Is there a way to get the finish materials to wrap around the roof?
Nachricht 4 von 7
Martijn.Pater
@jfjacques perhaps you could share (part of) the file to have look at it...
Nachricht 5 von 7
jfjacques
It's just a roof.
Nachricht 6 von 7
RDAOU
@jfjacques
It seems to line up fine as expected...See GIF below...
  • On the horizontal ... like any other pattern
  • Because it is a roof by extrusion on the slopped edge aligning to another material on different elements will reset the pattern alignment to 0/90 degrees .
  • Using a Facia is an option
  • if your intent is to get rid of the horizontal lines in the pattern - simply use a model patter with Vertical lines only instead of a 90 degrees crosshatch
  • if your intent is to get the horizontal lines parallel to the roof angle while vertical lines of the pattern remain vertical to the floor, then the pattern used is not appropriate ...you will need a custom model pattern
Nachricht 7 von 7
RDAOU
als Antwort auf: RDAOU
Apparently this is a double post....main discussion seems to be happening on the following LINK Paint issue - Autodesk Community - Revit Products
