I have identified an error when there is contact between platform and subregion.
I have gone crazy this behavior, since it occurs when there is proximity, it is not necessary an express contact.
I thought it might be a phase failure.
Do you have any explanation?
Is it a mistake?
regards
as a quick solution maybe you can try to leave minimal offset - i.e. 1/32". Suppose it will even not visible
Hi @arqyt,
Looking at you screencast, here is your problem.
You are not talking about a subregion but a différent toposurface.
I can see that your contours do not match from one to the other.
1 is subregion,
2 is Split Surface. it creates A DIFFERENT SURFACE.
As a Pad belongs to ONE surface, it has to pick which one it belongs to.
It is what happens.
Merge your surfaces, and then create your SUBREGION.
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
