Overriding interior floor edges (holes)
5 ANTWORTEN 5
Nachricht 1 von 6
1487 Aufrufe, 5 Antworten
Hi everybody,
I'm trying to override the interior edges of my floors (holes). I need to show these in red colour.
I'm using the VV interior edges in floor category but nothing has happened.
I think I don't understand something.
Thank you in advance.
5 ANTWORTEN 5
Nachricht 2 von 6
Ilic.Andrej
als Antwort auf: Anonymous
"Interior Edges" are between the surfaces of the floor where we have different slopes.
For some reason openings cannot be overridden....So, you will probably gonna have to use some detail lines or filled regions. Anyway, the hole is usually there so that some other thing can go through it... So, you can override whatever that is.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 6
The quickest way I can thing of right now, would be to use the Linework tool (LW).
Create a new line style (Manage - Additional Settings - Linestyles), give it a name and the red color, then use the LW tool.
Nachricht 4 von 6
FAIR59
If you've used a Shaft for your holes, you can add lines to define the edges in the shaft editor.
  • Make a new linetype in [Manage][Additional Settings][LineStyles].
  • Select the shaft and [Edit Sketch]
  • Choose Symbolic Line and Select your newly defined LineStyle
  • Draw / or pick the edges of the hole.
  • Finish Edit.
In "normal" plan views you can hide the new linestyle in the view template or using Visibility-Graphics.
Nachricht 5 von 6
cbcarch
als Antwort auf: FAIR59
Were you able to make the symbolic lines RED, as the OP asked about? I tried it, but color did not change, as Shafts
seem to take on the Object Style of the Host Floor.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 6 von 6
FAIR59
als Antwort auf: cbcarch
Yes, I can. Though the floor gets drawn over the symbolic lines, which is weird. You have to make the symbolic lines
really thick, or maybe give them a slight offset.
