Override line type in interior elevation views
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mason
201 Aufrufe, 2 Antworten
The problem I'm having is where walls/floors/ceilings, etc. are cut, the line thickness increases. I'm trying to override this so that the line thickness doesn't change. I would think that using override in Visibility/Graphic Overrides (circled button in second image) would fix this, but it seems to have no effect. The two orange arrows in the elevation view show a wall that's cut at the top and bottom, but not in the middle (the elevation runs through a window in that wall). I want to get rid of all of the thick lines around the edges of the view.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: mason
Override the roof too.  You can also use the Linework (LW) tool to override linework.
Nachricht 3 von 3
mason
I was able to get it to work, thanks @barthbradley. You've helped me a lot lately; if I ever run into you in the real world, I owe you a beer! :Gesicht_mit_Freudentränen:
Another issue I was having was that I was changing the subcategories (boxed in orange) when I needed to be changing the main category (boxed in yellow).
