Override graphics for linked Navisworks models (coordination model)
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
Is it possible to override graphics & colors for linked NWC files inside Revit?
When using Visibilty Graphics I only see "Transparency" as an option(?).
Would like the printed file to show the linked NWC as grey (not a christmas tree of colors).
Thanks in advance!
rxi.gg
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Marcus.Isacsson
@rxi.gg wrote:
But this is inside Navisworks, correct? Do you mean that the override will follow into Revit?
We've linkned the NWC into Revit and want to override the graphics, just for the links in our model, not the actual files (if possible)
ankit.kYHRHK
Did we find any solution to this request Marcus?
I am hoping you say yes & share the solution with me.
RSomppi
We have almost zero control over the appearance of coordination models. The answer might be in the creation of the Navis file.
