Override Graphic in View - By material/By category
1 ANTWORT 1
Nachricht 1 von 2
mairh_tsek
1234 Aufrufe, 1 Antwort
I have made a floor with additional layers that is displayed in two sections. In the section 'A' when I go right click > Override Graphics in View > By element in the cut pattern I can select for color/pattern: By material, so in the section I have the representation that I want.
In the section 'B' for the same floor when I go right click > Override Graphics in View > By element in the cut pattern I cannot select By material but only By Category Override. So, I don;t have the representation that I would.
Could you tell me why I have this different between the two sections and how I can have override by Material in the second section too?
Thank you in advance!
1 ANTWORT 1
Nachricht 2 von 2
mairh_tsek
als Antwort auf: mairh_tsek
Ok,I found the reason,
I had override the floor by Overrides Grapgics in View > by category and I had already assigned a color in the Cut Pattern.
