Overlaying multiple Revit floors...
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
sstattelman4GLLM
3104 Aufrufe, 2 Antworten
Okay, lets see if I can explain this without being super confusing. I have a circular project that ramps up to multiple levels. However, this is a school project and I don't want to show 5 different floorplans, so I'm trying to find a way to create a floorplan that looks like it is cutting through 4 feet on each level, instead of the lighter underlay that isn't as graphically pleasing. I was just wondering if this is possible, or if I should photoshop the different levels onto one another. Again this isn't for a construction document, just a visual aid. If you need anymore info or the file just let me know.
Thanks!
Sean
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: sstattelman4GLLM
You can create floor plans of the levels that you want to see with different cut planes and then overlay the views on a sheet.  You can crop each view to see the part that you want to see, and change each graphically to suit.
Nachricht 3 von 3
sstattelman4GLLM
als Antwort auf: Anonymous
Thanks Tim! Didn't think of that at all, should work though!
