I am trying to achieve a tiled wall sweep, to look like terracotta tiled wall. I have attached the image of my wall sweep it is currently like timber wall siding, I can't work out how to put in the vertical gaps to make it tiles. Could you provide any suggestions about how to achieve this?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
I tried to do that but when I put vertical reveals in they go in the rest of the wall but they are not cutting through my sweep
@Anonymous
To model the exact shape you would need to
Alternatively you could spare yourself all the hassle of complex modeling and all the sweeps and reveals and simply apply a decent material which looks slightly similar...It took me 3 mins to google Terracotta Walls Tiles and download the below image from some website HERE and I'm pretty sure if you search you will find something very similar to yours
You can try using massing and then use the adaptive pattern to create the effect you wanted. See attached
