Overlapping Lines on VECTOR PDF
10:20 AM
When I print a PDF, with printers such as Adobe PDF, Microsoft to PDF o PDF Converter, in mode VECTOR, there are some lines form other workplanes on the cutting lines. This happens to me with the "Region edges mask coincident lines" unmarked. if I print with "Region edges mask coincident lines" marked, it improves a bit, but not at all. In none of the cases appear on the vector PDF what I can see on the Revit screen or on a RASTER PDF. I've attached images of these cases.
This happens to me with every file, computer, template... I've also attached an image of 3 simple walls with one floor below, and you can see how the green of the floor is on the cutting lines (Revit 2020, "Region edges mask coincident lines" unmarked).
