Overlapping floors not able to select for hidden lines
4 ANTWORTEN 4
Nachricht 1 von 5
chubbard
607 Aufrufe, 4 Antworten
We have two floors at different elevations that overlap. We would like to dimension to the lower edge so the formwork is correct. But when i try to use the Hidden line tool i am able to select the upper floor but not the lower even though i can see the edge in the tool. Without resorting to detail lines how can we get the floor to display the hidden line?
4 ANTWORTEN 4
Nachricht 2 von 5
RobDraw
als Antwort auf: chubbard
Have you tried temporarily hiding the upper floor?
Rob
Nachricht 3 von 5
chubbard
als Antwort auf: RobDraw
Cannot use the hidden line tool if the upper floor is hidden.  And the drafting comment is counterproductive.
Nachricht 4 von 5
RobDraw
What is the hidden line tool?
Huh? It's a joke. Ha ha! Get it?!
Rob
Nachricht 5 von 5
I'm not sure why Hidden Lines is not working for you. Wireframe the View, click on Show Hidden Lines, pick edge of foreground element,  pick edge of background element, change view to Hidden.  Hidden Lines don't show up?  Floor not within View Range?  Maybe you can use a Plan Region to mitigate.
