Overlapping curtain walls with regular walls
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
2968 Aufrufe, 4 Antworten
Hello, saw a tutorial in wich explain the overlapp between walls and curtain walls.
In the video, before put a regular wall (screeshot 1), after click on curtain walls (screeshot 2), select where is put the regular wall and then there is curtain walls between the two ends of the regular wall incorporated in that (screeshot 3),
I can't do this. If I try to do this say me maybe there is a type of wall will come hide to the other.
Recommend to cut a wall to incorporate one wall to the other (screeshot in other post).
Someone can help me?
Thank's
4 ANTWORTEN 4
Nachricht 2 von 5
MostafaElashmawy
als Antwort auf: Anonymous
I think you need to check the parameter Automatically embed in the curtain wall type properties.
Mostafa Elashmawy
Nachricht 3 von 5
Screenshot appears to me and .rvt file.
Nachricht 4 von 5
als Antwort auf: MostafaElashmawy
Thank's very much!
Nachricht 5 von 5
s45560552
Legenddd
