Using the Linework Tool would be one approach.
..ah, families. Why not do the overhead lines as detail items/symbolic line work?
@barthbradley wrote:..ah, families. Why not do the overhead lines as detail items/symbolic line work?
They won't show in the plans if they're above the cut plane. There's a workaround though, placing an invisible line downwards from the family (making the family being cut and thus showing the symbolic lines).
Is the workaround the 'best' way to go?
It is a common workaround. Do you want to show them as overhead lines on floor plans and as normal lines on ceiling plans?
@Marcus.Isacsson wrote:They won't show in the plans if they're above the cut plane.
I'm not following you. I said Detail/Symbolic linework, not Model linework.
We want to show where they are with overhead lines. Do you mean using an underlay then manually lineworking all the contours? This can take quite some time.
I guess that the workaround with an invisible line could be a better way?
http://revitrocks.blogspot.com/2012/09/the-old-revit-invisible-line-trick.html
I'm referring to linework in the family -- not the project, which I initially was referring to when I mentioned the Linework Tool. I'm suggesting placing detail/symbolic lines directly in the family.
The Model Line Trick is a great way to make geometry above the cut plane visible, but I thought you were more interested in representational line work.
@barthbradley but those symbolic lines won't show without using the "invisible line trick"? Or am I doing something wrong? Can you post a pic or video?
See another workaround. This takes advantages of a Generic family as a shared/nested family.
Symbolic line work is always placed at the "Detail Plane" of the view (e.g. the plane that is closest to you as you look at the view).
