Over Constraining Parametric Window
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
BigPicture045
371 Aufrufe, 8 Antworten
I have a window made with reference lines so that it is adjustable in 3D views. I need to add a head height so that I can control that with an instance parameter. However, I am having trouble with over-constraining:
Any suggestions? All my tries have lead to over contraining....
A
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: BigPicture045
Share the family here.
Nachricht 3 von 9
BigPicture045
als Antwort auf: ToanDN
Shared - see attached.
Nachricht 4 von 9
This work?
Nachricht 5 von 9
See family.
Nachricht 6 von 9
BigPicture045
@ToanDN , Thanks for the modifcation. However, these windows were created specifically for design work and need the flexible areas you can see in 3D views. You can see this fixed window with the grabbers here:
Unfortunately, with the mods made to the family, only the width is adjustable and the top grabber controls the head height.
I do not need the head height to be a grabber, that can be a standard instance, but I still need a grabber to control the height of the window.
Nachricht 7 von 9
BigPicture045
Do you know how I can still have the height grabbers? Only the width grabbers are visible.
Nachricht 8 von 9
BigPicture045
Nevermind, I had previously changed a reference plan to not a reference. Changing it back to weak gives me the grabbers again.
I've posted the family for anyone interested. Thanks.
Nachricht 9 von 9
I guess I misunderstood. You want Shape Handles.
Like this:
Constraining to Strong Reference Ref. Lines will get you there.
