Oval basin - modelling help
NP---MD
NP---MD
Hello!
Can anyone either share a model of an oval basin with me (not a dowboaded BIM product, but a parametric or at least editable model) or talk me through what modelling tool you'd use in a family to model it.
I'm struggling a bit and cannot find a decent youtube tutorial.
Sweep doesnt seem to want to work annoyingly.
Thanks!
RSomppi
DowNloaded families are parametric and editable, for the most part. You just need to get them from reliable sources. I'm sure you can find a sink that fits your needs from one of the major manufacturers in your area.
NP---MD
Thanks, I'll search again then.
I find models from manufactuers behave in a way totally unfamiliar to me. And, I use Revit a lot - am not a beginner.
RSomppi
Not all families are created equal. Some are quite simple with no options. Some are overly complicated. Others fall somewhere in between. They may be designed for use outside of building design or made on the fly out of necessity. Don't make opinions if you are unfamiliar. It could get cause you to discard something very useful.
Good luck.
