Outline in filled region not showing
16 ANTWORTEN 16
Nachricht 1 von 17
2845 Aufrufe, 16 Antworten
How do I make the outlines of the region visible?
The outlines in my filled regions (which are set to a line that is visible, not invisible lines) do not show when my filled region is transparent, they only show when it's opaque. It didn't happen before, I must've changed something by mistake but I can't find it.
16 ANTWORTEN 16
Nachricht 2 von 17
aRcHiTeCt.JM
als Antwort auf: Anonymous
.... you can do the following
... click the filled region
... chose edit boundary from the menu
... click the lines and chose line style
.... that way you will have visible lines
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 17
als Antwort auf: aRcHiTeCt.JM
They are already set to a visible line (e.g. thin line).
This is the filled region ^
The lines do not show inside the house, but they do outside.
Nachricht 4 von 17
aRcHiTeCt.JM
... do you want to show the outerlines or the inside lines?
 .... for the inside filled region go to properties and chose one option
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 5 von 17
I want the outer lines to show.
They have always shown. I had many filled regions with outlines that were different colours and they were all showing. I dont know why they aren't showing now. I dont know if I have added a floor slab or a material to the floor or something that can affect?
Nachricht 6 von 17
aRcHiTeCt.JM
... you can also check the detail level
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 7 von 17
Yes, thanks,
It's already set to the finest one
Nachricht 8 von 17
aRcHiTeCt.JM
.... check the type properties as well
... mabe tweaking something will improve
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 9 von 17
Can it be something of the floor slab, or roof, or some other element that is not allowing it to show?
Cause the outline does show on the outside.
See filled region:
Nachricht 10 von 17
aRcHiTeCt.JM
... are you applying one filled region on top of another filled region or masking region?
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 11 von 17
No, I'm applying it on a LEVEL (+0.00).
This level has two slabs underneath: one is at 0.00 and one at -0.10.
When I delete the one on top, the outlines do show.
Nachricht 12 von 17
aRcHiTeCt.JM
... then I'm guessing there will be something to do with the settings in visibility/graphics
... check if you have something in slabs or graphics or views interfering with the filled region
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 13 von 17
Thanks for your help.. but can't find anything wrong / don't see the problem.
Nachricht 14 von 17
aRcHiTeCt.JM
... sorry for not being very helpfull
... do you want to upload the file so I can take a look?
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 15 von 17
Is this happening in only one view, or all views?
Nachricht 16 von 17
Is the filled region drawn inside an in place model family?
Nachricht 17 von 17
loboarch
Filled regions are detail elements, they have draw order.  Is it possible the 1/2 where you can't see the lines is "behind" another detail element?
Select the filled region and on the contextual tab use the draw order controls to bring it to front.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-8369F5F7-35D4-434A-9BF7-4120014F4506
Jeff Hanson
Principal Content Experience Designer
Revit Help |
