Outlet annotation lineweight not changing when altered in object styles.
3 ANTWORTEN 3
Nachricht 1 von 4
222 Aufrufe, 3 Antworten
I'm using the out of the box outlets from Revit.  I did a save as to create a new family and named it Oulet-Duplex-New.  I'd like the new outlets to show up darker than the existing but when I change the object style line weight it doesn't seem to do anything.  What am I missing?
3 ANTWORTEN 3
Nachricht 2 von 4
kadmonkee
als Antwort auf: Anonymous
try setting up a filter using comments for that category electrical devices.
select a item to set as NEW in the comments section of the properties
be sure to include generic annotation and / or Detail Items as categories too.
NEW displays as an override oclor and line weight
EXIST stays as placed apply the filter to those views
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 4
Mert_Yacan
By default, the annotation lines for outlets are drawn in the Generic Annotations category.
You can change the line weight for Generic Annotations in your project object styles settings.
If you want to change the category of these lines, you need to edit the annotation family inside the outlet family.
- Double click to the outlet to open the outlet family
-Open plan view
-Double click to the annotation open the annotation family
-Open object styles settings
-Create a new category
-Set line weight
- Select the lines and change their category
- Click load into project to load your edited annotation family to the outlet family
- Select your outlet family
- Load your outlet family to your project
- Now when you open the object styles settings of your project you can see and edit the new subcategory you created.
Nachricht 4 von 4
Turn Thin Lines (TL) OFF.
