Other side of the wall is black
3 ANTWORTEN 3
Nachricht 1 von 4
411 Aufrufe, 3 Antworten
Hi! can someone help me? i dont know what happened suddenly some of my walls in my model becomes like this. the other side of the wall becomes black but the other side is the original color (white) can someone enlighten me? i turned the shadows off already.image.pngimage.pngimage.png
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: Anonymous
change setting of your graphic display settings or shadow turn off and also check your materials setting of your wall and see if helps. thanks
Nachricht 3 von 4
I can't really tell from your images, but try set the views Phase Filter to Show Complete.
Nachricht 4 von 4
MostafaElashmawy
walls may show shaded in a shaded view  even with shades turned off.
If the two sides have same material and you want same color, try use "Consistent colors.
Mostafa Elashmawy
