OTB outlet label
4 ANTWORTEN 4
Nachricht 1 von 5
yes_and_no
266 Aufrufe, 4 Antworten
OTB outlet label
Guys, the OTB outlet has only one label family imbedded. The same DED outlets I place on the wall, one
came out with mirrored label. You know how to fix this ?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: yes_and_no
Spacebar Rotate fix it?
Nachricht 3 von 5
yes_and_no
als Antwort auf: barthbradley
I tried and tried.
I should say i have created a flip handle inside the family but without
success.
Nachricht 4 von 5
RobDraw
Delete and replace.
Rob
Nachricht 5 von 5
jmiller.geminibim
@barthbradley suggestion of using space bar to fix the issue should have resolved the mirrored label text. See link below to video demonstrating the fix. If you are not getting the same results as in the video, I would verify that your family has the Keep Readable parameter checked in your annotation family containing the label.
https://autode.sk/3nAGmf8
