*Edit - Resolved - These parameters were associated with a key schedule and key legend
I can't delete a parameter from a project. When the parameter is filtered in a schedule properties view it does not appear under any of the type filter options. It seems like the parameter does not have a parameter type. When the family is copied into a new project the parameters do not appear.
Hey, I've got a door family that has a number of parameters that I would like to delete. In the project, I hover over the parameters they are described as "Global Parameter" "Drop Down List". These parameters are not visible in the family file. I've copied the door family into a new project that contains no global parameter's. The parameters contain a dropdown field with a number of pre-set text items that cannot be edited or added to. I suspect the family was created approx 5 years ago in Revit light. I've tried to overwrite the parameter by creating -
- project parameters with same name
- shared parameter with same name
-global parameter with same name
The result is a duplicate parameter. I tried deleting with dynamo but failed.
Does anyone have any ideas or do I just rebuild the family from scratch
Thanks in advance for you ideas
Gelöst! Gehe zur Lösung
Gelöst von luke9R9ZN. Gehe zur Lösung
Can you share the family so we can examine them?
If those parameters are not in the Family, they must be Project Parameters.
