Origin of CAD Import
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
510 Aufrufe, 4 Antworten
while import to cad dwg to revit rfa in the object some surfaces are missing in revit.
in the cad it shows perfect the same object import into revit  some surfaces are missing why it is happen ?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
What kind of surface is it? Revit does have problems with, or won't convert some AutoCAD surfaces.
Nachricht 3 von 5
Sir,
I'm not sure which kind of surface it is. so that the reason i attached properties of that surface.and the exactly  that surface is missing in revit.
Please find the below attached file.
Nachricht 4 von 5
Viveka_CD
Hi @Anonymous
Can you make a block and try exporting again?
Nachricht 5 von 5
als Antwort auf: Viveka_CD
Thank you So much
