where the command to put the import pattern with dirrerent orientation?
For basic there is orientation, for custom no..
Thank's
Gelöst! Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
The custom pattern is a pattern made out of revit and loaded to it as it is.
so in case you want to rotate it, load it rotated.
Mostafa Elashmawy
If you are asking because your hatch seems rotated in view, just orbit the view and you will notice that the hatch will change its orientation while orbiting.
Also look at the roof plan and you will find that your hatch is ok.
Mostafa Elashmawy
1) I've taken the pattern just from that site.
How can a recognize what I'm choose is a drafting pattern.
And which is not?
2) I try with some titles .pat.
Why if I put 0.2 scale is visible only from 1 side and when i put 0.1 scale is no visible?
When i do render there's something visible?
Thank's.
@MostafaElashmawy which program can I use to open .pat file?
I download Gimp but don't open file.
Any text editor.
Right click on the file
Open with
Notepad
Mostafa Elashmawy
