Orientation Confussion
1 ANTWORT 1
Nachricht 1 von 2
247 Aufrufe, 1 Antwort
My Revit model is confusing when looking at the orientation, and trying to figure out which way it is facing. In plan view, the north face of my building is facing up, but looking in 3D view the north face is actually facing south, messing with the sun angles. This wouldn't usually be a problem because I should just be able to rotate the building to the correct orientation, but when I try to do that the 3D camera views I have already set up do not go with it. The question I cant figure out is whether there is a way to rotate the camera views along with the rest of the building, or if there is a way to reset which direction the ViewCube in the top right corner faces.
1 ANTWORT 1
Nachricht 2 von 2
Sahay_R
als Antwort auf: Anonymous
Sounds like you have True Notth set up. Go into Location and change the value of True North to 0.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
