Orbit crashes Revit
7 ANTWORTEN 7
Nachricht 1 von 8
mccotterarchitecture
630 Aufrufe, 7 Antworten
Orbit crashes Revit
Has anyone else been having a crashing problem with Revit 2022?    I have narrowed it down to orbiting with the mouse in a 3d view after I have had the program open for more than 30 minutes.   There is no warning and I usually lose about 30 minutes worth of work when it happens.    I will be working along without any issues.   I switch to a 3d mode and while holding the shift key with the middle mouse button attempt to orbit.  Previously in the work session I will have done this without issue.   At random occasions the model will not orbit and everything freezes.   Each time, I think the software just needs to catch up and about 30 seconds later Revit just closes.    When I open it back up, of course the file is back at my last save.    I am not sure if this is a hardware issue, though I haven't had crashing problems in years with Revit.   I remember when it crashed pretty regularly :strahlendes_Gesicht_mit_lächelnden_Augen:
7 ANTWORTEN 7
Nachricht 2 von 8
Have you installed the 2022.0.1 hotfix?
Nachricht 3 von 8
Yes, I did all the updates last week hoping that would resolve the issue.
However, it is still occuring
Nachricht 4 von 8
What's the status of "Allow Navigation During Redraw" under Options=>Graphics?
Nachricht 5 von 8
syman2000
als Antwort auf: mccotterarchitecture
Do you have CAD link in the 3d environment or any adaptive component family?
Nachricht 6 von 8
Have you found a solution to this? I have the same problem.
Nachricht 7 von 8
No, I haven't. It has happened in two projects now and I just trained
myself to save before going into 3d.
Nachricht 8 von 8
Thanks for your reply, I'm still waiting on one from Autodesk!
