Is there a way to decide which properties are matched using the Match Type Properties? For example, if I want to apply similar "override graphics in view" I should be able to just use the brush instead of doing like 5 clics. Same for Phasing. If I want to change many objects (walls, roofs, doors...) to "demolished". There are many cases in which this may be useful so I refuse to believe there is no option to do this.
There is no option...they gave you dynamo as well as access to the API so that you can be relative and make your own options and tools
Refer to below post and check the graph from reply 9... you can expand on that to add all the options you mentioned
https://forums.autodesk.com/t5/revit-architecture-forum/match-grapics-overrides/m-p/10643990
