OPTION TO EXPLODE IS GREYED OUT WHEN I SELECT AN IMPORTED CAD FILE. WHY?
ugina
Message 1 of 14
ugina
THE OPTION TO EXPLODE IS GRYED OUT WHEN I SELECT AN IMPORTED CAD FILE. WHY IS THIS OPTION GREYED OUT?
THANKS
Replies (13)
Message 2 of 14
Redrunner92
Is the imported CAD file pinned? If so, unpin it.
Message 3 of 14
ugina
I DON'T BELIEVE IT IS. I DON'T SEE A PIN TO CLICK ON TO UNPIN OR PIN.
Message 4 of 14
Redrunner92
Would you post an image of your screen so we can see what you are dealing with?
Message 5 of 14
ugina
Message 6 of 14
PavelAnd
Hi @ugina . Are you sure you imported the cad file, not link? The explode button is gray if you link cad file. Try importing your cad file again.
Best regards, Pavel Plotitsyn.
Message 7 of 14
Go to Manage Links dialog box=>CAD Formats=>highlight Link name=>press "Import" button=>press "Ok" to close dialog box=>select Link/Import in View=>press "Explode" button...
Message 8 of 14
Ruban_Nadarajah
The above solution works. Thank you
Message 9 of 14
RSomppi
I wouldn't import and explode. It puts unnecessary junk in the model.
Message 10 of 14
seelam3TKPF
Community Visitor
Community Visitor
I had a similar issue and this solution worked for me as well. Thank you!
Message 11 of 14
samsonlJN95P
Community Visitor
Community Visitor
It worked for me, thanks!
However, when I exploded the CAD file, all the colors changed to black. Initially, I thought this was due to missing line styles, so I created a line style matching the original CAD file colors. But even after that, the exploded elements still appear in black.
Has anyone else experienced this? Any suggestions on how to retain the original colors after exploding?
Message 12 of 14
kadmonkee
it is never recommended to explode an imported Cad File, as stated in a previous reply, it creates more clutter and trash in your model.
a better and cleaner method is to link in the cad file and pick select the line work (trace) to create a native Revit detail for better use
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 13 of 14
Sleepingfish_Kuo
Don't create the line styles yourself, it will generate automatically.
If you already have one with the same name, Revit use it instead of a new one.
Message 14 of 14
RSomppi
Did you assign those lines to the new styles that you created?
Retaining the original colors can be done in the import dialog box.
This article may help with additional information.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Imported-DWG...
