Option bar bugged menu
3 ANTWORTEN 3
Nachricht 1 von 4
mcorriveau
183 Aufrufe, 3 Antworten
I am experiencing an issue with a dropdown menu in Revit 2020 that is persistently displayed in my option bar. Unfortunately, I cannot recall the exact steps I took to place it there. Currently, I am unable to remove it as there is no right-click menu option available, and it is overlapping with other crucial menu items, hindering my workflow.
Could anyone guide me on how to remove this dropdown menu from the option bar?
Thank you in advance for your assistance!
3 ANTWORTEN 3
Nachricht 2 von 4
ralphdenhaan
als Antwort auf: mcorriveau
Are you using multiple monitors with different scaling? Maybe you can check that first?
Also trying to restart Revit and updating your drivers?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 4
mcorriveau
als Antwort auf: ralphdenhaan
I am using a single ultra-wide monitor. I've been experiencing this issue for several years now, so I don't believe it's a glitch. I recall intentionally configuring it this way at one point, but unfortunately, I can't remember the steps I took to do so.
Nachricht 4 von 4
ralphdenhaan
Hmm,
This is the same topic here: https://forums.autodesk.com/t5/revit-architecture-forum/option-bar-dropdown-issue/td-p/9039317
Maybe you can try to reset your UI: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-the-A...
