Option and Main Model overlapping when parts displayed
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
cbt990
429 Aufrufe, 4 Antworten
I have been developing design options and I may have created some overlapping elements accidentally.
I need to be able to delete the extra wall in each option but still have one editable wall remain. Once I delete what seems like a redundant wall, I can no longer edit the other one.
Revit is amazing
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: cbt990
An option can overlap other options, but should never overlap Main model.  You just have to fix elements in the Main Model and in each Option with that principle in mind.
Parts have nothing to do with any of this.  Fix the originals.
Nachricht 3 von 5
cbt990
als Antwort auf: ToanDN
i had an extra part (original?) in my main model.
Revit is amazing
Nachricht 4 von 5
cbt990
What is the difference in functionality between "adding" an element to an option set and copy/pasting it in from the main model?
Revit is amazing
Nachricht 5 von 5
DrakeCanyonArchitecture
You would want to cut and paste as opposed to copy and paste as @ToanDN stated. The idea is that your option will occupy that same space in the main model, so you don't want your option to land right on top of an instance in the main model. I generally use reference planes in the main model when it comes to cutting walls, this way you can see the reference planes in every option and use them to snap to.
Kevin Mendenhall
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
