I wanted to ask if its possible to add decal or a picture on a individual panels. It's technicaly an optical illusion, when you look from a specific point you can see a picture?
Yes, you can place decals. They might work a bit differently from other software but it is possible
Louis
Please mention Revit version, especially when uploading Revit files.
A Decal that is only visible from a specific Angle?
Nope, I do not believe that is possible. When you place the Decal, it is either you see it or you don't (in Realistic mode or Renders)... Revit doesn't do magic tricks and illusions ![]()
If you do not want to see is in certain camera angles you will have to improvise
GIF 1
GIF 2
Perhaps this video and some sample may help you
https://www.youtube.com/watch?v=YyPl9IjxAHc
Do you mean something tike this? A louvered facade that reveals an image at a certain viewing angle...
If you are talking about anamorphic projections (See wikipedia Anamorphosis), I have done this in the past but in workflow including 3DS Max and Sketchup. As this was before FormIt, the workflow could be adapted to work with Revit materials and allow you to illustrate the anamorphosis within Revit Realistic views.
If this is what you are trying to do, here's the basic outline:
-luc
Here's an example:
Original image:
In model 3DS Max projection:
Here's a rough version of a test on a rectangular prism. Each side would be saved to a different material.
And the floor had this material
Word of the Day: "Anamorphosis".
Thanks @lucdoucet_msdl
Funny; spell check doesn't even know this one.
@kristina.podinskaite wrote:yes, like that
Pretty simple construct. Image is on a thin Basic Wall Type behind a Curtain Wall Type. The Curtain Wall has angled Interior Vertical Mullions and all Empty System Panels.
Have fun!
No it will not...Again Decals on their own simply applied to a surface do not behave the way you described. It is either you see them or you don't. (Refer back to message# 3)
Any optical illusions you want to create, you will have to improvise and do them using other means (hoping that such means suits/fits the design intent) or other software
@kristina.podinskaite wrote:but it won't work if it's glass behind?
I don't understand your question, but what I showed you above is not a Decal. The colorful Koi image is coming from Wall Material's Appearance Image. If you want that Wall/Image to be glass-like when Rendered, then use the Image for Transparency and play with those settings.
