openings through wall sweep
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
3144 Aufrufe, 9 Antworten
First of all i want to make sure what i have done is the right way to do it? ( false wall with top and bottom sweep)
2. I want to create series of opening as i mentioned in the red. wall openings does not create a void through the sweep
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
You can cut those "notches" in a wall sweep with an in-place [Component] void cut.
Nachricht 3 von 10
I believe the "join geometry" tool will cut a single opening through both walls.
Modify > Geometry > Join
Nachricht 4 von 10
als Antwort auf: barthbradley
thank you very much for the reply,
when i tried in-place void cut, it just removes a segment of the sweep; it does not make  a puncture
Nachricht 5 von 10
Corsten.Au
create multiple sweepscreate multiple sweeps
Corsten
Building Designer
Nachricht 6 von 10
I thought you were decorative notches, not penetrations all the way through .
 How tall and deep is that sweep? It almost looks like you're doing an wainscot.  Normally we model wainscots as walls -- either separate wall or as the lower portion of Stacked Wall Type.  If you can do it way, you can penetrate
with an opening.
Also, are you aware that you can build sweeps into Wall Types?
Nachricht 7 von 10
yes, i want penetrations all the way through.
Nachricht 8 von 10
Corsten.Au
1.  Use wall profile and cut those openings
2: other option is use “ windows” to create those opening . Create a new window family with only opening rectangle / square .. no panels..
windows in on the wall by default cuts the wall sweeps..
if you want to continue some part of sweeps vertically, then you may create multiple sweeps and control the design..
cheers
Corsten
Building Designer
Nachricht 9 von 10
als Antwort auf: Corsten.Au
''2: other option is use “ windows” to create those opening . Create a new window family with only opening rectangle / square .. no panels..''
it Worked...
Thank you very much...
Nachricht 10 von 10
FWIW: This is what I was talking about. Stacked Wall Type with built-in Sweeps (not Sweeps applied later using the Wall Sweep tool) can host Openings that will cut through the Walls, as well as the  built-in Sweeps.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
