Opening wall not working anymore
mariaome1991
mariaome1991
hello I am trying to create an opening in a wall and them model in place a window. However when I click on the wall and then on the vertical wall opening no opening is created.
how can I create this? It has worked previously.
se.ha
Hi @mariaome1991,
there is no vertical wall opening. Vertical obviously doesnt work on walls, try just wall instead:
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
alan.johnson7YLND
If you are going to create the window as a model in place you could include the opening for the window while creating the model in place window as there is an opening tool on the create tab.
Otherwise like @se.ha said use the wall opening tool not the vertical tool (that is for floors, ceilings and roofs)
In-Place Modeling a Window? You can't use those Opening Tools. Use a Void Extrusion in the In-Place and Cut the Wall before exiting In-Place Modeling Mode,
