Hello fellow colleagues,
the following problem... Maybe someone of you knows a solution...
Opening symbols of windows and doors point in different, mirrored directions in Revit and BIM 360.
Why is this and how can it be fixed?
Gelöst! Gehe zur Lösung
Gelöst von michael.plat.001. Gehe zur Lösung
Look at a 3d view in Revit. I bet it looks the same as the one on Bim360 viewer.
Edit the window family and fix the 2d elevation swing (symbolic lines), or the 3d swing (model lines) so that they match.
The 3D view in Revit looks exactly like the 2D view... And mirrored in BIM 360.
So window families are correct.
Then it is a bim360 viewer problem. You can go to Revit cloud worksharing forum to ask the question.
Odd. Never encountered that before.
I'd like to know what you find out should you discover the reason this is happening.
Thanks in advance.
Autodesk's solution is described here:
I haven't had time to test this solution yet.
